87 Warrior No Start Weak Spark
Old Jan 7, 2006 | 09:21 AM
giles45shop's Avatar
Default 87 Warrior No Start Weak Spark
Okay,
I'm getting frustrated. I picked up this Warrior from a friend, it hadn't been ridden in several years. It needed a new starter which I replaced, along w/ a new battery and new spark plug.
When I hit the starter button, the starter turns the engine just fine, but it won't fire. When I pull the plug and ground it against the engine, I get a blue spark very intermittently. In 2-3 seconds of cranking it may only spark one time, if at all.
I began diagnosing w/ a Clymer manual.
Checked the spark plug boot and it showed open, so I replaced it. Same results as above.
Checked the coil, it showed bad, replaced it, same results as above.
I'm going to check the stator today.
Anyone have any ideas? I thought about the CDI, but someone told me that if it wasn't working there would be no spark at all.
Thanks,
John
Old Jan 7, 2006 | 01:01 PM
DavidLT250S's Avatar
check all the wires because they might be cracked or rotten and yeah check your stator for sure thats what i hate about electric start fourwheelers everything f*cks up on them kick start is the way to go
Old Jan 8, 2006 | 09:27 AM
Looks like stator is bad. When I checked across both pairs of wires as described in the manual, One pair gives a reading within the resistance spec (189 ohms) and the other pair shows open.
Where's the best place to get a replacement? I'm thinking Ricky Stator, but I don't know anywhere else other than the dealer ($$$) or used on E-bay (?? reliability). Any recommendations appreciated.
Thanks,
John
Old Jan 8, 2006 | 10:26 AM
warriorryder's Avatar
order it from the ricky stator website....Ricky Stator
Old Jan 8, 2006 | 04:51 PM
Thanks. That's what I was thinking. Looks like it will be another delay until I get this thing running [img]i/expressions/face-icon-small-sad.gif[/img]
John
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
jag6510
Jun 15, 2015 05:59 PM
sae156
1) Engine problems..
Jun 3, 2015 01:45 PM
1000gade
May 27, 2015 12:37 PM
