help me please! 250r no spark
Old Jan 7, 2006 | 01:43 PM
hillbillysmw's Avatar
Default help me please! 250r no spark
have to ride today, checked all grounds on my 250r, no spark, tried 4 different plugs. this might be a dumb question but will a 400ex coil switch out? probably not im guessing
Old Jan 8, 2006 | 07:37 PM
250ex4now's Avatar
Last time I had the same problem on my R it turned out to be the Boot. I replaced the plug boot and she fired right up.
Old Jan 29, 2006 | 01:27 AM
Hahnster's Avatar
check all your butt plugs wiring conectors did it just all of a sudden do this ? you can check the mag assy and the impulse coil with a ohm meter i dont know the specs but if impulse coil has zip then its impulse coil now the CDI could be the dont know of a tester for them
also check your kill switch just unplug it to isolate the switch
good luck
Old Jan 30, 2006 | 11:08 PM
xbourget's Avatar
I might be too late but I would change out the CDI unit, thats usually the cause.
Old Feb 4, 2006 | 11:47 PM
mean650's Avatar
check all the things everyone said and if theirs still no spark, pull the cover off the stator and see if water leaked in there.sand the tab and check the spark. i have an extra coil and cdi.
Old Feb 14, 2006 | 01:56 PM
TrxR's Avatar
I had alot of problems with the stock kill switch assembly. Bypass it and see if that helps. I now have a simple bush botton kill switch from a XR on mine because of it.
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Slagpolaris
Sep 5, 2015 09:41 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
