raptor 660 cams
Old Jan 7, 2006 | 02:41 PM
fasterthanyou22's Avatar
Default raptor 660 cams
What are some good cams for a raptor 660 and what kind of power increases will i see with a cam on stock bike and on pipe, filter , and jet.
Thanks,
~Mike~
Old Jan 7, 2006 | 03:48 PM
Yamaha660R's Avatar
A Stage 1 Hot Cam is the best drop in cam on a stock motor. You won't have to change the valve springs, or anything. It also seems to be the most popular cam for all stock engines....it's a low and mid range cam. You would definetly feel a improvement with it over stock.
Old Jan 7, 2006 | 03:52 PM
Okay, so no stage 2 til i get cylinder work right?Stage one will be good enough for full pipe, pro flow, and jet?And would i have to rejet for a cam or no?
Old Jan 7, 2006 | 04:04 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
I agree with Yamaha660R........
I'm running a stg. 1 HC in my dirt Raptor. I noticed some GOOD power changes in the bottom end and some mild changes in the mid range, NOTHING on the top end........
All in all the stg. 1 HC is a good drop in cam and works well too.......[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 7, 2006 | 04:09 PM
Yamaha660R's Avatar
You won't want to do the Stage 2 Hot Cam unless your going to have some head work done, and the valve springs replaced. The Stage One is a drop in cam....you don't have to do anything else to the motor to run it.
Old Jan 8, 2006 | 10:25 PM
Thats good.Thanks guys.I think i know what i am gonna get now for around 130 bucks.Well, Ill prolly get the dial a jet kit too.I gotta think tho.Im gonna get the cam first then im gonna get a dial-a-jet and proflow for b-day or earlier if i get a job.But yea...thanks guys.
Old Jan 9, 2006 | 05:15 AM
Rockinfigs's Avatar
ok im also getting the stage 1 HC...how hard is it to install one of these?? can i do it myself or will it need special tools to install which means taking in somewhere to get it installed?
Old Jan 9, 2006 | 10:35 PM
Dude, it is an easy 2 man job...Take off the plastic and gas tank and then the top motor mount.Then take off the bolts to the valve cover in a criss cross pattern so you dont warp the head.Then have a very RELIABLE friend hold the cam sprocket for you if you arent replacing the sprocket and take off the stock cam and make sure nothing falls into the motor (decompression plates).Then put on the new cam.Btw, it is a hell of a lot easier to drain your oil and freeze too.Dont worry, just get a service manual and you wont have to follow my steps.
Old Jan 14, 2006 | 05:17 AM
maddog56's Avatar
I disagree, the stage 2 hotcam can provide worthwhile gains without head porting. While porting will obviously enhance and increase the output, the stage 2 itself is still a good upgrade without it.
bmxatv10
Oct 14, 2022 06:23 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
black_thunder
Sep 22, 2015 07:59 PM
