600 griz, hard starting
Old Jan 10, 2006 | 08:34 PM
Ren's Avatar
Ren
Default 600 griz, hard starting
My friend has a 99 Grizzly and has a hard time getting it starting, sometimes. Battery is new. Will go on the pull cord. Sometimes no power to lights and to the key. I'm thinking that it's electrical but we don' t know where to look. Any info appreciated.
Old Jan 10, 2006 | 10:09 PM
getdrunk's Avatar
could be a bad regulator
Old Jan 12, 2006 | 09:21 AM
Ren's Avatar
Ren
ty. will check it out
Old Jan 12, 2006 | 04:28 PM
hondabuster's Avatar
Check the grounds too.
And the two connections on the battery. The metal needs to be shiney, and clean, and the connection needs to be tight.
Old Jan 12, 2006 | 09:45 PM
getdrunk's Avatar
im having troubles with my 400ex. for me its the wires i think. i have to push on all the wires with my foot or the starter wont work and the light flicker alot.
Old Jan 17, 2006 | 01:03 AM
Hebs's Avatar
Hard starting because of power issues?? no clicking.... no turning over?? Or hard starting like it just turns over and over but won't kick in?
Reason I ask, I have an `02 griz and recently had issues with it not wanting to start. It would try and try... but it took forever before I could get it to turn all the way over. The valves were a lil tight and needed to be adjusted. Now it turns over right away... even in the cold Illinois weather....
hope this helps....
Old Jan 17, 2006 | 01:42 AM
raptor8's Avatar
I agree with Hebs: immediate starting problem is electrical of course [?] so check and clean all connections on battery AND starter. Remember those guys have the world's weirdest sounding starter, which doesnt have a long life - it may be worn out. start shopping for a starter JIC. they are available aftermarket.
The larger issue is hard starting and in my experience the harder it is to adjust the valves, the harder it is to start the quad since the maintenance does NOT get done. take an afternoon and adjust those valves and it'll start right up. let me know how it goes, PM. [img]i/expressions/face-icon-small-cool.gif[/img]
Old Jan 17, 2006 | 09:35 PM
getdrunk's Avatar
for my 400ex battery problum i found out it was a loose connection under a lil red cap covering the whires so i couldnt find any thing loose till i looked their and their was no bolt holding it to gether. that was my problum.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chinkapin
Jul 14, 2016 06:58 AM
toonces
Jun 30, 2015 11:19 AM
1000gade
May 27, 2015 12:37 PM
