Yamaha Warrior Plasticd
Old Jan 11, 2006 | 02:57 PM
YamahaRider8998's Avatar
Default Yamaha Warrior Plasticd
Hi i have a 1996 yamaha warrior and the plastics on it are really a bad color and are beat up. where is the best place to buy plastics on line. Also is using a dremel the corroect way to cut plastics if not what is?
Old Jan 11, 2006 | 06:05 PM
recon99's Avatar
Maier makes good plastics for the warrior, both stock replacement and yfz-styled plastics, in almost any color you could want. Go to www.maier-mfg.com to check it out. There are lots of ways to cut fenders, and a dremel is a good way to do it. You just have to go over the cut edges with some fine sandpaper to make them smooth again, and you can carefully use a torch to remove the whiteish color the sanding leaves. If you use a torch try it first on the part of the fender you cut off, so you don't over-do and mess up the good part of your fender.
2quiker
Mar 22, 2022 08:36 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
