sp700 need power computer carb model
Old Jan 12, 2006 | 10:23 PM
ghandi's Avatar
Default sp700 need power computer carb model
I have been looking for a computer to get more take off power whats the best thing to do for my polaris sp700 twin carb model. Cant find a computer anyone got any suggestions. Have an epi clutch kit already on it. Will do a little wheelie on flat ground but i would like a big a** wheelie. Please reply.
Old Jan 12, 2006 | 10:54 PM
SPORTSMAN70003's Avatar
I have never seen a module for a carbed model. You can put a 800 primary clutch on it and gain alot of low end.
Old Jan 13, 2006 | 03:37 PM
sportsman2004's Avatar
Sportsman70003--since i can not figure out the messenger thing...when you installed your spacers, did you use a spring clamp? I just got my spacers cut and I am going to install them tonight. Any advice is appreciated....
Also, your reverse override..is that a kit, or did you do it yourself. I got some instructions on how to do it with my 3 way headlight mod...but don't like the fact that the display will say error when the override is on.
Thanks for your advice....
soon to come...
800 clutch
800 header install
800 snorkle mod
DO you know all the part numbers for these mods??
Old Jan 13, 2006 | 06:53 PM
I assuming your are talking about the spacers under the spring. I did use a spring compresser. Jack up the front and do one side at a time. Take your axle nut off and undo your tie rod end. Next put the spring compresser on. Then undo the the top nut on your strut. Then undo the 2 bolts on your strut housing that holds the strut shock in and then slide the strut shock out of the strut housing. Make sure you don't let you cv pop apart thats why you take the axle nut off to let the axle slide in and not pop apart. Slide you spacer on and reinstall everything back.
800 Header part # 1261445-029
800 Snorkle part # 5435932
800 Primary Clutch part # 1322495
I have the reverse override and will try and dig it out and give it to you. I know it works for the 03's but I'm not for sure it will work on the 04's.
Old Jan 14, 2006 | 03:53 AM
Did you buy a spring compresor...or just make one. I would hate to go buy one for just this time...
Old Jan 14, 2006 | 07:25 AM
I really think you can do it without the compressor since I have heard alot of people say they didn't use one. My dad has worked on cars for many many years (over 35) and he has almost any tool you could think of.
Old Jan 14, 2006 | 09:00 AM
Bill35's Avatar
Like sportsman said.DO NOT LET YOUR CV JOINT COME APART.like I did on both sides.That sucked
Old Jan 14, 2006 | 07:06 PM
so, against your wisdom...I let the CV boot pop when I gave it one good pull downwards to get the spring out...
So, what do I have to do to pop the CV back together?
Old Jan 14, 2006 | 09:25 PM
Well you need to take the big clamp on the cv boot off and then line the splines up and push it back together.
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
toonces
Jun 30, 2015 11:19 AM
