My oil smells like gas...Normal?
Old Jan 17, 2006 | 04:00 AM
PSDan000's Avatar
Default My oil smells like gas...Normal?
noticed when i did my first oil change that the oil smelled like gas. was wondering if this is normal? checked it again a little while after the oil change and it still smells like it. thanks
dan
Old Jan 17, 2006 | 10:21 AM
butzla's Avatar
It's not normal...sounds like the rings are not seated properly and gas is allowed to seep in from combustion chamber into crankcase. Most likely happened during break in period.
Old Jan 17, 2006 | 10:35 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
i disagree with that entire statement
gas will leak past rings,,,seated properly or not
Sounds like a sticky needle valve that wont close all the way and fuel is just running into the head.
do you shut your fuel off when you arent riding?
If left unfixed,,,you could do a lot of damage. The gas basicly washes the oil off the cylinder walls and provides no lubrication.
Old Jan 17, 2006 | 10:52 AM
encorebilly's Avatar
It's just the smell of the polaris oil.Took mine back to dealer for the same thing.No problem.Smell the new oil.Same smell from 05 500ho and 05 700efi.
Old Jan 17, 2006 | 02:33 PM
PSDan000's Avatar
yep, always shut the fuel off. any of you guys ever burned your old oil? i did when i changed mine, we had a few fallen trees to burn up so i dumped it on there and it went up like gas. thing is, there doesnt seem to be any excess fluid in the crankcase. thanks for the help
dan
Old Jan 17, 2006 | 06:17 PM
zerowick's Avatar
first oil change on mine was the same, that's why I changed it at 10 hours, smelled heavy of gas. after switching to AMSOIL 0W-40 Formula 4-StrokeŽ Power Sports Synthetic Motor Oil there is no more gas smell.
Old Jan 18, 2006 | 07:06 PM
butzla's Avatar
Here's a good link on proper break in
bigred20653
Oct 2, 2015 10:05 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
