Kazuma mini falcon 90
While trying to change the oil, I removed the wrong plug. I removed what I now know is the timing chain tensioner plug. When I removed the bolt, a spring came out, and then a rod dropped down. The rod didn't come out of the engine block, but i was able to spin it and noticed that it had some slots cut into it. I pushed the rod back up into the block and replaced the spring and bolt. My question is, did I do any damage. Does the position of the rod matter due to the slots? Or if it all fit back together, is everything ok. Thanks for your comments.
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
