Info on eton viper 50 upgrades
Old Jan 15, 2006 | 03:56 PM
4wheelin83's Avatar
Default Info on eton viper 50 upgrades
i have an eton viper 50 lookin to do some upgrades to it to up it performence. if any one has any info it would be great thanks.
Old Jan 15, 2006 | 05:16 PM
HQR109's Avatar
what do you want to do, the list is endless for that little quad, big bore kits, pipes, clutch kits, a-arms, swing arms and i could go on.
Mark
Old Jan 15, 2006 | 06:30 PM
4wheelin83's Avatar
for right now i just want a little more pep out of it. something to make it a bit faster. oh and any idea where i can get a wire diogram of the ignition i want to get rid of the whole having to use my key to start it up.
Old Jan 16, 2006 | 03:59 PM
Fishez03's Avatar
What year is it? If it is pre-2004 you can cut the green wire on the back of the CDI box and disable the rev limiter. This is a huge improvement if it applies.
The best bang for the buck would be to get a quality pipe from WRH Racing or Hetrick, a less restrictive air filter, jet the carb up, lighten the rollers and increase the stall. The difference is night and day compared to the stock set up...
Old Jan 16, 2006 | 05:12 PM
4wheelin83's Avatar
it is a pre 2004 and which one is the cdi box? their are 2 boxes on the front where alot of the wires go. and i read about someone else doin this and he had a problem when it warmed up that it did not run right. thanks for the info let me know. also still need info on the ignition wires thanks guys.
Old Jan 17, 2006 | 12:33 AM
Fishez03's Avatar
Stand in front of the quad and look down the right side of the right side of the steering stem just under the handle bars. The CDI box is in there, most likely in a rubber sleeve that attaches to a peg. Just pull it loose, remove the rubber sleeve and on the back of the box a green wire "loops" in and out of the box. Cut the wire in half and make sure they can not touch. Put the sleeve back on and put it back in place.
The only thing it affects is the rev limiter, so having problems when it warms up would be a separate issue. We cut ours about 2 years ago on our 2003 and have had no problems whatsoever. Our neighbor down the street cut his over a year ago as well.
I put a male connector on one side and a female on the other side of the green wire and can "reactivate" the rev limiter if necessary. (when my little nephew is in town)
Cutting the wire increases the performance a bunch, but nothing is a substitue for the pipe, filter and jets.
Old Jan 17, 2006 | 02:55 PM
4wheelin83's Avatar
what company would be good to get this stuff from "exhaust pipe, jet kit, and filter" oh and also what spark plug would be better then stock?
Old Jan 17, 2006 | 03:03 PM
Fishez03's Avatar
www.wrhracing.com
www.hetrickracing.com
These are the only two that I've done business with and you can't go wrong with either. I'm sure there are other good people out there, but Billy and Rich are top notch and have never disappointed. They know these mini's inside and out!!!
Old Jan 18, 2006 | 02:51 PM
4wheelin83's Avatar
its a 2003 eton viper 50 and i looked on both cdi boxes and i do not see any green wire that come out and back into the cdi box?
Old Jan 18, 2006 | 03:14 PM
Fishez03's Avatar
Did you pull the cover off the box? If it is a 2003, it is in there unless the CDI has been changed out for some reason...
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Minimod
Sep 10, 2015 08:03 AM
