scrambler trans fluid
Old Jan 18, 2006 | 04:48 PM
500scrambler4x4's Avatar
Default scrambler trans fluid
ive been told so many rumors about what kind of fluid to run in the trans. from friends, now ill turn to the pro's. can i just run some good trans fluid in it from a car? if i do run regular ATF in the trans what will happen. it thats all a bad idea what type of fluid should i run then? then last but least what should i run my my front diff. any help would be great!
Old Jan 18, 2006 | 04:58 PM
Bretman's Avatar
well what have you herd, i just go to polaris and get there stuff
Old Jan 18, 2006 | 05:03 PM
i dont have a dealer around for a very long distance and ive heard its very expensive. alot of my friends just run regular good trans fluid in them, they never have problems, but is it good for them. ive also heard of guys using good quility motor oil in there trans. so what should i run?
Old Jan 18, 2006 | 05:51 PM
anybody?????
Old Jan 18, 2006 | 07:22 PM
ftwflh's Avatar
I wouldnt run automotive tranny fluid in it.You need a good chaincase lube.THe synthetic Polaris AGL fluid is $11 a qt but is recomended.Not a bbig deal when you only change it once or twice a year.You can run automotive trans fluid in your hubs but if you do it is best to use Mobile1 synthetic.The front end uses a good grade of 80w90 lube.If the prices of polaris lubes are too much drop me a pm.
Old Jan 19, 2006 | 12:02 AM
16polaris's Avatar
I called my local Polaris dealer and they told my that they use a synthetic 0W-40 motor oil. They said for me to get Mobil 1 0W-40 synthetic.
Old Jan 19, 2006 | 12:57 AM
Eastfork's Avatar
16polaris,
They told you to use 0w-40 synthetic in the gearbox(transmission)?
JC
Old Jan 19, 2006 | 05:51 AM
jimmypsp700's Avatar
I have a 2000 model (Scrambler) and the trans takes (PPS) Polaris Premium Synthetic gear case oil (weight?).
Not sure if this is the same as AGL fluid.
BBScrambler said You can use Amsoil Series 2000 Chain case lube. It works as a substitute to the Polaris AGL fluid.
It doesn't specify the AGL fluid (like my sp700) but its still not Auto Trans fluid such as used in cars.
A lot of different fluids (auto trans to 80w90 gear lube) have been used in the trans' buy others saying they had no problems. (used with their sleds, model "X" atv etc...)
I'm not so sure myself.
I know I won't stray from the (PPD) Polaris Premium Demand Drive (Synthetic) fluid in the front Differential on my sp700.
Jim
Old Jan 19, 2006 | 07:25 AM
16polaris's Avatar
16polaris,
JC
YES, They told me that 0W-40 was the same thing as the Polaris trans fluid, and they said it was cheaper too, so thats what i've been using for a long time now.
Old Jan 19, 2006 | 01:11 PM
Hoopie's Avatar
Jimmypsp700, Forgive my ignorance but how do you change the transfluid in the 2000 scrambler 400?
