Race Mod Spark Plug gapping?
Old Jan 20, 2006 | 11:53 AM
16polaris's Avatar
Default Race Mod Spark Plug gapping?
I was wondering what a BR9ES should be gapped at for the Race Mod 400's with the stock ignition?
Thanks!
Old Jan 20, 2006 | 12:33 PM
POLARISFREAK's Avatar
.018
Old Jan 20, 2006 | 01:59 PM
Bubba297's Avatar
unless it's on alky I would run the B8EG or B8EGV, or even the BR8EIX. They cost more but they have a finer tip and it takes less current to fire it.
Old Jan 21, 2006 | 07:34 PM
scramblered's Avatar
BR8ES at .018 to .020,
hotter plug make more power in those fuji motors and burn more
efficient.
fine tip spark plug is for very close to perfect jetting conditions,but
i havn't seen any gains using them.
Old Jan 22, 2006 | 01:02 AM
16polaris's Avatar
I use a BR9ES because Darrell from HPD told me that is the plug I should run with the race mod.
Old Jan 22, 2006 | 02:46 AM
handycap's Avatar
Holly crap, you are supposed to gap your spark plugs ! Gap at .018
What plug do you run with Alcohol with all the race mods?
After the $300.00+ ignition mod you can gap to .025
Old Jan 22, 2006 | 03:00 AM
IdahoVinnie's Avatar
I may be wrong here, but I don't think that a finer tip requires less current to fire. A closer gap requires less voltage, but not a finer tip. Generally a finer tip is made with a material that doesn't wear as quickly, thus keeping the gap within specs for a longer period of time.
Old Jan 22, 2006 | 11:01 AM
handycap's Avatar
BUBBA knows,
Just one of those things we all learn on this forum.
Put your normal spark plug connected to spark plug wire in your hand and crank over engine, feel the bite. Now try the fine wire plug and feel the bite. You can test the spark plug of your choice many times at different gaps to determine the best bite (ZAP) for the buck.
Old Jan 22, 2006 | 01:54 PM
CED's Avatar
CED
You need to try holding the plug with the new ignition and the plug gapped at .035.Man that sucker will make you holler.[img]i/expressions/face-icon-small-shocked.gif[/img]
Big bousse
Sep 26, 2015 10:42 AM
Dirtbikemike1
Jul 21, 2015 04:13 AM
ghost civic
Jul 19, 2015 10:13 AM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Unzzy66
Jul 11, 2015 10:01 PM
