Head Gasket, smoking????
Old Nov 7, 2000 | 04:28 PM
Sanddude's Avatar
I havn't been riding since I got my motor done, just a few puts around the dairy. So today I went for a good ride, bout 15 minutes, and I stopped and looked over the motor, and I saw a little bit of smoke rolling off of the cylinder head. So I putted back to the shop and cooled her down. Now I assume its just the gasket sort of seating? but you tell me, any help will be appriciated. thanks
Old Nov 7, 2000 | 04:46 PM
Zorro's Avatar
Are ALL bolts tightened wih the same torque?
If smoke comes out from the head, something's wrong...isn't the cyl or head scratched where the seal sits?Isn't the seal broken? Maybe your head overheated and bent. When all bolts are not torqued the same, that's what happens, even without overheating. Check if it's straight.
Old Nov 7, 2000 | 06:50 PM
PHATTYBOY's Avatar
FIRST CHECK ALL HOSE CLAMPS ON HEAD AND RADIATOR..
...IT SOUNDS LIKE THE HEAD GASKET IS LEAKING....
DO YOU HAVE O-RINGS ON HEAD OR GASKET??? YOU CAN
USE PERMATEX COPPER GASKET SPRAY ON GASKET TO SEAL
HER RIGHT UP!!(YOU CAN BUY AT LOCAL AUTO PARTS)..
HAVE YOU TAKEN HEAD OFF BEFORE???
Mikegriff92
Technical and How-To Articles
Oct 26, 2015 02:40 PM
SDR-II
Sep 29, 2015 01:06 AM
Jason Poulin
Sep 20, 2015 02:49 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
scram5050
Sep 3, 2015 05:06 PM
