Brute force 650i Toe-in or Toe-out
Old Jan 22, 2006 | 11:01 AM
Rhinosoarass's Avatar
Default Brute force 650i Toe-in or Toe-out
I just bought a new Brute force 650i, went riding last weekend and I noticed a little bit of bump steer, then noticed that the Brute has a good bit of toe-out. Does anyone know if this is set up by the dealer or is it set up by kawasaki? My experience has been that toe-out increases bump steer. How do you guy's have yours set up? This is an awesome machine and I think I'll be much happier with it than I was with the 650 cat. Thanks for your Input.
Old Jan 22, 2006 | 11:07 AM
handycap's Avatar
Better to turn out than in.
Most manuals show toe out for specs on quad alinements. From zero about a 1/4 inch on each wheel.
But check with Kawasaki and have the dealer check it out for you.
good luck...........handycap
Old Jan 22, 2006 | 12:43 PM
montyh's Avatar
i think you outta have it looked at. mine doesn't bump steer. i'll see what the manual says next time i look at it.
monty
Old Jan 22, 2006 | 12:56 PM
grizzkiller's Avatar
i think my brute 750 was set at zero in or out. since then though i put on diamond g rods and ends and now mine is toed in just a hair. i think thats what ktm265 runs. he's the one who makes the rods that diamond g sells.
Old Nov 16, 2006 | 04:59 PM
jasons650i's Avatar
will setting toe to zero or even giving the 650i some toe in help it to steer easier and remove that shaking as i take long race track turns?
also, what is bump steer?
Old Nov 16, 2006 | 06:13 PM
alltoos's Avatar
On my 05 750 and my 06 650. They were both sent from the factory with some toe-out. Along with that. The handle bars were crooked on both from the factory. I set my 05 750 to 0 toe-out and the 06 650 to 1/8 toe-out on each wheel. I don't race. But the way I ride, I can't tell any diff. My issue was with the crooked handle bars from the factory.
Old Nov 16, 2006 | 06:29 PM
montyh's Avatar
the 650i service manual doesn't give toe specs. just that each tie rod is supposed to be 15.48 inches from center to center. i set mine at 1/8" toe in when i put tie rods in it, and i have no problem. it handles better than new.
try a little toe in and try that. i couldn't find a way to measure the tie rods that closely, but it is easy to set toe in.
monty
Old Nov 16, 2006 | 06:50 PM
Hayashi's Avatar
Almost all Kawi's V-twin quad's front wheel toe-in spec is ZERO +/- 10 mm.
Set it to toe out (+ ), if you want easier/looer steering feeling for easy slow riding on soft terrain.
Set it to toe in (-), if you want stiffer/quicker steering feeling for fast trail riding on hard packed terrain.
Old Nov 16, 2006 | 10:03 PM
montyh's Avatar
where did you find that kawi spec?
monty
Old Nov 16, 2006 | 11:24 PM
Doctorturbo's Avatar
GOT BOOST!
Toe has nothing to do with bump steer. Bump steer is caused by having a poor relationship between the pivot point of the tie rod and the A arm, strut or whatever. A good suspention system will have the pivot points in line.
"Slight" toe out will make a "slightly" more stable ride but will cause "slightly" more heavy steering. Toe in will cause the opposite.
