83-200 atc
Old Jan 24, 2006 | 09:09 PM
agloo7's Avatar
Default 83-200 atc
Hi does someone know how to test ignition coil for spark plug, should there be a certain ohms resistance.Just the coil without wire.
from primary to ground secondary to ground or between primary and secondary.
Old Jan 25, 2006 | 12:21 AM
1988TRX250R's Avatar
Default 83-200 atc
remove coil from bike. primary side to ground should be around 1 ohm. secondary side to ground w/ the plug cap removed will be around 5K ohms. plug cap itself will be around 5k ohms also.
Old Jan 25, 2006 | 02:46 PM
ThrashAndCrash's Avatar
Default 83-200 atc
No offence, but when you Ohm out something...the specs are never "around" they are exact range.......had a coil at work yesterday that failed a Ohm test by 0.2 ohms and we replaced the $300 coil.
Primary.... 0.2-0.8
Secondary....8-15K
Old Jan 27, 2006 | 02:21 PM
agloo7's Avatar
Default 83-200 atc
Thanks for the tip tested it off bike sec to gr, pri. to gr , sec to pri all read 345 ohms
