200s clutch
Hi my clutch level is not catching the grooves on the rod that come out of the transmission. The clutch just spinns around it. I cant get the clutch to come off. I loosend the bolt that holds it on but didnt come off. Also if i have to replace the rod, do u have to take the engine apart to get it off. Can i just weld the clutch lever on? Can you fix the the grooves on the rod by making them deeoper and tighting down the clutch level better?
