help my 03 raptor wont start from battery only from bump start
Old Jan 25, 2006 | 04:18 PM
englishraptor's Avatar
Default help my 03 raptor wont start from battery only from bump start
i have had the engine fully rebuilt my a engineer and i starts then stops on the button and wont run again the only way to get it to run is pull it behind a car and it will run then
tried everthing like
carbs cleaned
mixture screws
filter
new plug
new cdi
new stator pac
new 1 way bearing
new coil
new start/stop button
checked timing and all good
please help raptor experts in usa
ow its an 03 by the way
Old Jan 25, 2006 | 04:24 PM
hondabuster's Avatar
When you press the starter button...what happens? Nothing, no sounds at all? Or, Itll spin the motor over, but it just wont start?
Old Jan 25, 2006 | 04:26 PM
yes mate it spins over but thats about it and when you take the plug out getting plenty of juice and a good spark
Old Jan 25, 2006 | 06:14 PM
Hows the valve clearance?
Old Jan 26, 2006 | 12:11 AM
CTracingraptor's Avatar
i beleive your valve clearance is to tight, and you should loosen them up.
Old Jan 26, 2006 | 12:19 AM
the valve clearances were set to the yamaha seiint manual so i would guess they were right
Old Jan 26, 2006 | 03:33 PM
so maybe your guy messed up(it happens) i advise you to take the tank of and check them yourselves. its very easy.
Old Jan 26, 2006 | 04:25 PM
If youve taken the spark plug out, and visually checked for spark while cranking the starter....and you see spark, that only leaves compression or fuel as the cause. First thing to check is the valve clearance.
Old Jan 26, 2006 | 05:56 PM
Dwags's Avatar
if it is not valves then i would recomend cheching the fuel system, from the fuel petcock on the tank all the way to after the carbs.
tiresharkdbb
Sep 3, 2017 02:06 AM
wannabe32
Jul 7, 2015 11:30 AM
dnm48
Jun 14, 2015 10:11 AM
dano00
May 23, 2001 10:30 PM
