need help fast please
Old Jan 26, 2006 | 10:09 PM
UltimateAussie's Avatar
Default need help fast please
hey yall would putting regular premix two stroke oil in an injector cause the bike to bog down really bad, because i ended up with a bike that is bogging down really bad and i think it has regular golden spectro premix in it.
thanks
Old Jan 27, 2006 | 02:13 AM
bump
i would like to know before tommorow so i know if i need to get some when i go to get some other parts in the morning
Old Jan 27, 2006 | 05:09 AM
rruser's Avatar
I'm not sure if I understand your question. Are you saying you put generic oil in the oil tank of a oil-injected bike? I have never heard of that causing any bog problems. A bog on a 2-stroke could be caused by many things. In most cases its from running too rich (air/fuel wise). Check your plug and see if its pretty wet/oily. Also do a compression check if you have a guage. Also make sure there isn't any holes rusted in the expansion chamber or header of your pipe.
Some more info on the motor would help: How long have you had the problem? How long have you owned it? Any mods? if so, do you rejet the carb for the weather?
Old Jan 27, 2006 | 12:56 PM
yeah what im saying is if there is pre mix 2 stroke oil in the tank, could it cause the bike to bog down.
the bike seems to be oil fouling but i think thats becuase either the oil is the wrong oil and too thick or its injecting too much of the oil its got
Old Jan 27, 2006 | 06:18 PM
Z40005BR's Avatar
Clean your injector, and your carb, because it is probably plugged up. Dont put 4 stroke oil in there either. Never put 4 stroke oil in a 2stroke mix. Other than that, make sure on the 2 stroke oil bottle it says injector safe otherwise youll blow your piston. But clean your carb good to begin with.
Old Jan 27, 2006 | 08:21 PM
i cleaned the carb really good i even chem dipped it. and then hosed it out with carb cleaner. could the injector be whats causing the engine to bog down kinda bad. every once in a while the thing seems like it will clean out and it will go really fast but then it just bogs right back down
thanks
Old Jan 28, 2006 | 12:58 AM
Z40005BR's Avatar
check ur reeds if theyre soft get new ones otherwise its jetting
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Irishman301
Sep 23, 2015 01:47 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
