A Arm bushings showing wear.
Old Jan 27, 2006 | 01:29 AM
BajaX04's Avatar
Default A Arm bushings showing wear.
I am not sure if this is worn that bad but I noticed that if you grab a front tire and rock the top in and out and put your hand at where it attaches at the frame, it feels sloppy. Is there a better bushing? Or maybe bearings? This could be some of the odd 70mph scary feeling.
Old Jan 28, 2006 | 12:51 AM
BajaX04's Avatar
Anyone?
Old Jan 28, 2006 | 01:17 AM
FatHolly's Avatar
There should not be that much play in the a arm. New bushings seem like they would be in order if you are going to keep the stock arms. Your other option is to look at the ASR upper a-arms. They come with new heim joints all around. This would not only take care of the wobble you talked about but they are also adjustable for camber and caster which is why you feel that high speed jitter. I got mine on Ebay for about $150. It might be worth looking into.
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Sw00p
Sep 24, 2015 02:50 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
