kfx 400 mods help please
Old Jan 27, 2006 | 08:07 PM
inferno's Avatar
Default kfx 400 mods help please
what is the cheapest and less amount of work you can do to a kfx that is pretty cheap
Old Jan 28, 2006 | 11:03 AM
skyharborcowboy's Avatar
Seems like the cheapest thing everyone raves about is an ignition upgrade.
Joe
Old Jan 28, 2006 | 01:53 PM
BlackKawi400's Avatar
DRZE base gasket. it raises the compression about a point. Easiest and cheapest! Like $10
Full Pipe and open airbox with K&N filter
FCR Carb 39mm-41mm
Actually you really need a full pipe man!!! Seriously!!! And get an aftermarket filter and open up the airbox and rejet!
SIDE NOTE: You won't see the benefit of an ignition upgrade until you probably go with cams. The ignition's main point is that it raises the rev limiter up to 2000rpms. without cams you might never see that. Also, you should upgrade the stock springs to drze springs or aftermarket before going that high, otherwise you might float a valve.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
