06 Pred fan question
Old Jan 27, 2006 | 10:27 PM
06TLDPreddy's Avatar
Default 06 Pred fan question
I'm wondering if my 06 Pred fan is behaving normally. The fan is on almost constantly, even when the weather is in the low 70's and i'm cruising along at a decent speed the fan still comes on most of the time. Is that normal?
Old Jan 27, 2006 | 11:29 PM
spyder6's Avatar
yep, the predator thermostat is set very low
Old Jan 28, 2006 | 12:28 AM
Webopper's Avatar
That, and she may be a little lean from the factory. Had a bud of mine richen his up to a 155 without any other mods, and that cooled it down a bit.
Old Jan 30, 2006 | 12:39 AM
speedfreek500's Avatar
I had the same problem with my 05 tld.I let the motor cool down until i could touch the motor,then pull off the rad cap,start motor until the top rad hose get's warm,check the collant level in the rad,fill if needed,put the cap back on and enjoy.That is called an air lock.My fan still run's ,but not as often.When you stop you can keep the fan on for about 30-45 second's then start her up for 30-45 sec.and the motor will cool down faster.
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
