06 Pred fan question
I had the same problem with my 05 tld.I let the motor cool down until i could touch the motor,then pull off the rad cap,start motor until the top rad hose get's warm,check the collant level in the rad,fill if needed,put the cap back on and enjoy.That is called an air lock.My fan still run's ,but not as often.When you stop you can keep the fan on for about 30-45 second's then start her up for 30-45 sec.and the motor will cool down faster.
BYC
09-25-2015 02:10 PM
Quadzilla Heritage
09-25-2015 01:39 PM
