Idle changing!?!?!
Old Jan 28, 2006 | 01:34 AM
yamahalltheway's Avatar
Default Idle changing!?!?!
Ok first i apologize for the name [img]i/expressions/face-icon-small-happy.gif[/img] well to my question.. my buddy has a 02 rancher 2 wheel drive no electric shift. Last year he got a new jug piston well lets just say a whole new top end... Ever sence his rebuild he has had problems with his idle...The idel would go up really high then go so low it would die.. he would shift into neutral and it would rev to the sky then once in gear would run fine till he stoped then ether rev up or die.. Realy strange Hmmmmmm well i was wondering if y'all had any answers to this mystery B/C my yamaha has never done this nor have a heard of it... thanks in advanced
P.S. the reason i am posting this is B/C his computer crashed
Old Jan 28, 2006 | 08:23 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Seems like this has to be a carburator issue. When I have had an erratic idle, it has been clogged jets from dirty gas. A good carburator cleaning and flush out the fuel tank, is a good place to start.
Old Jan 28, 2006 | 09:19 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
sounds like an air leak
Old Jan 28, 2006 | 04:54 PM
ahh thought it was a carb problem ty
Old Jan 28, 2006 | 07:33 PM
recon99's Avatar
yes probably an air leak. Try wiggling the carb and the other intake tubing around and see if the idle changes from it.
Old Jan 28, 2006 | 08:19 PM
Martyr's Avatar
sounds like air , spray wd-40 around intake hose and carb idle should smooth out. And that would tell you air leak.
Old Jan 28, 2006 | 09:50 PM
Hahnster's Avatar
yes that would be my guess if still dosent change might pull off the mag cover and squirt a little in there to see if idle changes
Old Jan 29, 2006 | 09:49 PM
alright i will check the air thanks..
COFatboy
May 2, 2020 12:06 AM
Cummins Driver
Sep 11, 2019 01:22 PM
house1
Aug 9, 2015 10:49 PM
ghost civic
Jul 27, 2015 03:15 AM
ranvette
Jul 12, 2015 06:34 AM
