2001 TRANS IN A RAPPY!!!!!!!
Old Jan 28, 2006 | 07:30 PM
ThrashAndCrash's Avatar
Default 2001 TRANS IN A RAPPY!!!!!!!
Bud of mine has a 2001 rappy. In THIS link. It has a huge parts list. Do you need all those parts in that parts list to upgrade the trans? Or do I just need the two gears in the pic? n He has no prob with the trans right now, but he wants to prevent some!!!!!
Old Jan 28, 2006 | 08:06 PM
Yamaha660R's Avatar
If you look around at differnt sites...I believe www.albaaction.com you can purchase the 02' upgrade kit for $699.99!
It includes the following:
Transmission Rebuild Kit Includes..
All Gaskets including:
Head Gasket
Cylinder Gasket
Case Tensioner Gasket
Clutch Cover Gasket
Crankcase Gasket
Other smaller gaskets
O-Ring
Washer Plate
All Inner & Outer Circlips
All Lock Washers
OilFilter
Main Axle (12T)
2nd Pinion Gear
4th Pinion Gear
Reverse Pinion Gear
Reverse Wheel Gear
Collar
Shift fork #2
1st Wheel Gear
2nd Wheel Gear
3rd Wheel Gear
4th Wheel Gear
5th Wheel Gear
Oil Seal 2nl
Drive Gear
Shift Fork
I do believe there is cheaper places..but couldn't find them in a quick search.
Old Jan 28, 2006 | 08:18 PM
StockRappy01's Avatar
You need the whole kit and its worth doing before it fails. If you don`t it could cost as much again for the extra parts that are destroyed.
Old Jan 28, 2006 | 08:41 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
Thrash......Here's the lowest price 2001 Tranny upgrade kit that i've found........I agree, Rebuild the whole gear box........[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 28, 2006 | 09:31 PM
sixsixT's Avatar
That's a good price bigdaddy. I got a kit from craycraft for about the same price but I got his deluxe seal kit which includes every seal, washer, o-ring and the lock washers for the gears to reseal the whole engine. I also replaced all the shift forks and anyone else doing their tranny should do the same.
Old Jan 29, 2006 | 04:32 PM
Thank you guys for the info. I wasn't sure if that entire parts list was for after the trans blew, or was the upgrade. Thanks again!
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
chewy78
Sep 8, 2015 10:37 AM
