how to get this axle out
Old Jan 29, 2006 | 05:26 PM
trialsrider172's Avatar
Default how to get this axle out
ok, i have an 87 warrior, i need to know how to get the axle out. i've been trying to punch it threw. i've been punching from the side of the axle that the break isnt on. it just doesnt wanna budge...my question is am i trying to hit it out the right way? also, what might help get it out?
Old Jan 29, 2006 | 05:36 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
fully take the axle nuts off... fully take the spindles off... take the sprocket off.. then the axle should punch straight out on the right side.
Old Jan 29, 2006 | 08:59 PM
recon99's Avatar
Don't hit it directly on the end with a hammer, unless you're taking it out to put a new axle in. Hitting it directly with a hammer will damage the threads on the end. Put a block of wood up against the left side (sprocket side) of the axle and hit it with the biggest hammer you can find. It takes a while, and is much easier if you have an extra set of hands to hold the quad in place and hold the block of wood. It probably won't come out very easily, but if it does consider yourself very lucky. It took me and 2 of my buddies about 3 hours total and about 30 blocks of broken up wood to get mine out. Just keep pounding on it, and don't give up on it. It just takes a while to break it loose from the bearings.
Old Jan 29, 2006 | 09:11 PM
warriorboy22's Avatar
3 hours 3 guys one axle
noobs
just kidding
bent my axle the other day need to replace it so i hope its not 2 hard to remove.
Old Jan 29, 2006 | 09:14 PM
Speedy2222's Avatar
if yo uwant t ohit it directly with the happen put the catle nut on there first.. and hit the nut
Old Jan 29, 2006 | 09:40 PM
recon99's Avatar
Now that you say that, I remember that the block of wood didn't work for me! I put the castle nut on the end, and put a socket over the castle nut so I wouldn't damage it. I think it only took a couple minutes to get it out once I tried that.
Old Jan 29, 2006 | 09:43 PM
recon99's Avatar
Did you even read what you typed before you posted it? I had to read it slowly 10 times to figure out what the first half of your sentence said lol
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
