HPD parts
Old Jan 30, 2006 | 06:14 PM
ProBlaster92's Avatar
Default HPD parts
I noticed a lot of you guys have HPD parts and I was considering the airbox and carb mod for my scrambler. This comes with a complete jet kit right? Also is the airbox mod worth it? Thanks
Old Jan 30, 2006 | 07:34 PM
ftwflh's Avatar
Default HPD parts
The HPD airbox mod comes with a single main jet(170),a modded air tube,different vacum spring and a drill bit to open up the slide holes and the air snoot. After I put it on I noticed a huge difference in throttle response and mid range power.With the Dial a jet you will be ok.
Old Jan 30, 2006 | 08:46 PM
16polaris's Avatar
Default HPD parts
I don't have an air box on mine but I DO HIGHLY recommend ANY of HPD's products. They really work.
Old Jan 30, 2006 | 08:54 PM
gunman457's Avatar
Default HPD parts
Don't waste your money. You won't see any difference.
Old Jan 30, 2006 | 10:52 PM
Default HPD parts
It comes with a 170 main jet, what is stock? Right now i have the stock jet, but with the exhaust alone the dial-a-jet isnt enough fuel on level 5. Right now i need to go up at least a size or 2, even more with the air box mod.
Old Jan 30, 2006 | 11:15 PM
gunman457's Avatar
Default HPD parts
Stock jet is a 155.
Old Jan 30, 2006 | 11:22 PM
Default HPD parts
Ok and jets go in increments of 5 so thats 3 sizes. Thats probably about right but I would rather just have a jet kit... hey gunman, have you had a bad experience with HPD or something? just wondering cause i dont want to waste money.
Old Jan 30, 2006 | 11:47 PM
gunman457's Avatar
Default HPD parts
Yes I did have problems with HPD.
I ran a #165 with a HPD pipe and a K&N with a air box mod and the plug was black and my gas mileage suffered on trail rides. Went down to a #162 and it was still black but not as bad as the #165. Hope this helps you. Unfortunately the PVT trans sucks on gas mileage and when you do any mods, it justs make it worst if you like to do any trail riding. Then you have to pray for a gas station. My KFX is the same way, but i solved that problem by putting on a bigger gas tank. I don't think you can upgrade the Scram with a bigger tank.
Old Jan 31, 2006 | 09:58 PM
Default HPD parts
Alright thanks for your help guys
1986Vmax540
Jul 9, 2021 09:53 PM
DFWSRT8
Aug 20, 2015 09:24 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
