oil plug problem
Old Jan 31, 2006 | 04:46 PM
YamahaRider8998's Avatar
Default oil plug problem
when i went to change the oil on my 96 warrior the oil plu is welded on it looks liek. i tried as hard as possible to get it ooff and not a budge. It looks welded to. ive been using one of those topside oil changers recently but i wanted to know how i can fix this problem
steve
Old Jan 31, 2006 | 07:15 PM
bump
Old Jan 31, 2006 | 08:25 PM
Storj's Avatar
If it is truely welded on then you can drill it out and then tap out a new bolt size.
Old Jan 31, 2006 | 08:33 PM
recon99's Avatar
the warrior's drain plug isn't like one on a car, which is basically a bolt with a larger than normal head. The plug is about 2 inches across. I have a feeling you think just the hex head is the whole drain plug, when it's acutally that head plus the skirt around the outside. I don't think anybody would be that flat-out dumb to weld a drain plug in place. Warrior drain plugs do have a tendency to get stuck. If you can't get it off with a socket and breaker bar, try using a chisel and a hammer to make a groove in the skirt of the drain plug, and put the chisel into the groove at an angle to get the plug to break loose. This took me about 10 minutes to get broken loose, but at least it works.
After you get it out, go to a powersports shop and get a new one. The replacements my shop sells have a knurled skirt, so when it gets stuck you can break it loose by putting a flat screwdriver against one of the knobbies at an angle, and hit the driver with a hammer.
Old Jan 31, 2006 | 09:05 PM
Budwiser's Avatar
Same thing happened with me as recon99 said, but mine took about 20 min though. Also, it cant be welded unless its a different plug from stock or what they give u because u cant weld aluminum(the pug) and metal(the engine) together.
Old Jan 31, 2006 | 09:12 PM
wait, u mean that rind around the hex nut is part of the drain plug, ssssshhhiiittt, i feel stupid, wow!
thnx
steve
Old Jan 31, 2006 | 10:09 PM
recon99's Avatar
I figured that's what was going on. It's not hard to understand how you made that mistake.
Old Jan 31, 2006 | 11:53 PM
rruser's Avatar
You guys forgot the biggest tip of all for Warriors (or yamaha drain plugs in general) ...buy yourself a 6 point socket BEFORE you slip using a 12 point.
Old Feb 1, 2006 | 12:36 AM
recon99's Avatar
that will help sometimes, but i used a 6 point and still rounded out the head once.
Old Feb 2, 2006 | 05:27 PM
Budwiser's Avatar
Same here using the 6, then it went into a circle. Also, YamahaRider8998, get the right size in metric and dont force american size on it, or it will last shorter. (thats what the previous owner did to me!)
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
D-Hagz
Jul 4, 2015 02:19 AM
