Weighing Race ATV'S?
Old Feb 2, 2006 | 08:20 PM
16polaris's Avatar
Default Weighing Race ATV'S?
What is a good way to weigh a race quad if you don't have the proper scales? Can you use a hanging scale, or can you use a set of bathroom scales,( put the bathroom scales under 1 tire at a time and then add up all of the weights?)
Any help you be great.
THANKS!
Old Feb 2, 2006 | 10:05 PM
conig's Avatar
bathroom scales won;t work one wheel at a time.
you can load it in the truck/trailer and go to the dump/truck stop. weight the truck/trailer combo with the bike on then take it off and weight it again. truck stops are easier.
Old Feb 2, 2006 | 10:42 PM
GE4x4's Avatar
You need 4 good bathroom scales to do it. Don't buy the cheapest, but a mid grade scale. Put one under each tire then add the weight. It comes out very close +- a couple lbs. This also helps see how balanced your front to rear weight is to.
Old Feb 2, 2006 | 10:47 PM
16polaris's Avatar
What if I tied a rope to the grab bar and to the steering stem and used a hanging scale and a motor puller to gradually pick it up untill it is off the ground?
Old Feb 3, 2006 | 12:25 AM
HondaSlayer's Avatar
take it to the weigh station on the interstate if you want accurate weight. I have the manual for my trailblazer and the stockweight...i tried the bathroom scale trick and it was way off
Old Feb 3, 2006 | 12:54 AM
UBETRUN's Avatar
Get a hydraulic jack and use a bathroom scale that will read your quad's weight, about 350 lbs is the largest I've seen. Put the scale on the hydraulic jack and use a board to help balance the quad. You'll have to move the jack forward or back to find the quad's front/rear balance point, you need to get all 4 tires off the ground for an accurate reading. Check my pics.
Old Feb 3, 2006 | 11:07 AM
conig's Avatar
you will need a bathroom scale larger then 350. even 400's with frame lightening way in at over 350. unless the suspension is gone.
Old Feb 3, 2006 | 11:38 PM
Whitedog's Avatar
Heavy pigs!
Old Feb 4, 2006 | 08:03 AM
WIscrambler's Avatar
I bet my Scrammy with the engine removed weighs more than 350 lbs! Now if I can just figure out how to run the atv without the extra weight of the engine, I'll be good as gold! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 4, 2006 | 11:04 AM
UBETRUN's Avatar
Drag race ATVs are much lighter than you guys are talking, my new Raptor build should be under 300 lbs ready to race.
