more top end on my warrior
Old Feb 3, 2006 | 01:26 AM
BSMITH34WARRIOR's Avatar
Default more top end on my warrior
I just bought what i believed to be a 2000 Warrior with maxxis razr tires, a fmf exhaust, and the front end has been widened. It is a blast and i love riding but it does not have the top end speed that i expected. It is a 5 speed but i have read that some are 6 speeds, is this why i do not have the top end speed? What are some cheap mods that i can do to make it faster. Also, when did they switch warrior's to be 6 speeds and not 5? thanks.
Old Feb 3, 2006 | 01:30 AM
Glamis700's Avatar
I cant help ya with the 5spd\6spd question.
As far as adding top end to it, you said it already has exhaust, so go for a cam, ported head with big valves, big bore high compression piston, bigger carb with an intake and no lid on the box.
You may even add a tooth to the front sprocket to gain MPH.
Old Feb 3, 2006 | 02:31 PM
recon99's Avatar
Umm... I think there were a few 5 speed warriors made in the 80's, but a 2000 should definitely be a 6 speed. To gain top speed, all you need to do is get a bigger front sprocket. What size rear tires do you have? Let me know, and i'll give you a suggestion for the best sprocket size to get the most top end.
Old Feb 3, 2006 | 08:54 PM
Pelphrey's Avatar
Yeah you should mos def have 6 gears. 1 down and 5 are up. If you are running any tire smaller then the 22 that come in it dropping a tooth on the front sprocket could help...
Old Feb 3, 2006 | 09:00 PM
counterpunch's Avatar
I'm pretty sure there were no 5 speed Warriors, even on the older models.
Old Feb 3, 2006 | 09:11 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
87-88 and i BELEIVe 89's had 5 spds
Old Feb 3, 2006 | 09:22 PM
http://www.yamaha-motor.com/sport/ep...ior_small.aspx <<< wont let me link it for some reason.
Just a link to the Yamaha site with a brief summary of the 1987 Warrior specifications. It was a 6 speed.
Old Feb 3, 2006 | 10:39 PM
JTY2K's Avatar
Something doesn't add up, because since when was a Warrior a 5 speed instead of 6 speed. Lay off the fumes!!!![img]i/expressions/face-icon-small-happy.gif[/img]
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
