05 Predator Stering Stem Bent
Old Feb 5, 2006 | 11:58 AM
Bakeman's Avatar
Default 05 Predator Stering Stem Bent
I have a steering stem that was bent bad in a roll over. I bought a Roll Design after market stem and mount but there is no was to mount the stock dash board. I check out some after market billet dashes but all i have found only mount to the stock stem. If i go back to the stock stem an have a roll over again it will probably bend just like the last one. Has anyone ran into any steering stem problem? and does any one have an answer for mounting the dash if you use an after market stem? (IMS Roll or Lone Star)[img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 5, 2006 | 12:49 PM
predatordude2's Avatar
I got a Rath anti vibe stem and took the factory clamp that hold the dash on. I cut the hardware down to fit in between the handle bar clamps.
Old Feb 5, 2006 | 02:56 PM
Bakeman's Avatar
Thanks, that may work. Has anyone seen or used a after market dash bord?
Old Feb 5, 2006 | 03:15 PM
2manytoys's Avatar
Not sure why you want to change to a stronger aftermarket one? You need a weak point somewhere. If you strengthen the stem the impact is going to transfer to the next weakest point. that point may be much more expensive. I know on my mud trucks you try to make the drivetrain as strong as possible but you need a weak point to save the more expensive components. I know they hold up very well if you dont roll it. Dont roll it and you wont have that problem. I would think if you had a habbit rolling it you might want to change your riding style.
Old Feb 5, 2006 | 10:16 PM
Cutfoot's Avatar
I put a ROX dash panel on my 05 pred. Looks way better than the plastic stock one. I still have the orig. stem with ROX risers and Universal bars (all in black except risers).
Old Feb 10, 2006 | 04:52 AM
modquad's Avatar
Why wouldn't someone want to upgrade a steering stem. If you ride hard enough, "deviations from your intended vectors" often happen. Along with the Roll Designs stem, there is also the HPD, and Rath units. All add great looks and strength. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 12, 2006 | 01:47 PM
Bakeman's Avatar
I just upgraded to a Roll Design stem and bar mount, Rox/Roll Design dash panel and oversize Pro Taper bars. This upgrade looks great and feel much more natural than the stock bars and stem.The new dash looks great. The total cost was about $450[img]i/expressions/face-icon-small-smile.gif[/img]
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Albertaboyy
Sep 9, 2015 09:51 AM
meddy0388
Sep 9, 2015 06:41 AM
Elkaholic
Sep 6, 2015 02:44 PM
1966F100
Jul 12, 2015 03:01 AM
