350 and tires
Old Feb 5, 2006 | 06:34 PM
JeteNuts's Avatar
Default 350 and tires
im putting on 25 inch ITP 589's and im wondering if i would have any power loss and/or top speed loss? will i even notice it? ill probably look into getting a pipe too thanks!
Old Feb 5, 2006 | 08:06 PM
Torbinx's Avatar
Overall tire height increase is probably in the 5-10% range so you can expect a 5-10% power loss and a 5-10% top speed increase. If your speedo says your going 45 your probably going 50.
Old Feb 5, 2006 | 11:25 PM
JeteNuts's Avatar
how can i have a power loss and have a top end increase????? also im deciding between the ITP 589's and the Maxxis mud bugs! if there any difference between the two that would help me to keep my performance and also have a good mud tire?
Old Feb 6, 2006 | 12:28 AM
quicksilver's Avatar
yes, you can have a power loss but speed increase....
It basically raises all your gear ratios slightly higher. Try starting out in 3rd gear, you'll understand. 3rd gear gives you higher speed than 1st gear, but not as much power. The larger tires have a larger circumference, so they travel more distance per revolution. if you were driving at one revolution per second, the larger tire would travel more distance. more distance in a given amount of time equals higher speed.
The drawback is that it increases your speed but at the cost of power. Now your quad will be forced to move a few inches farther per tire revolution, thus causing a little more grunting of the motor.
In all honesty, i dont think you'll feel a difference at all. 25's are only one inch above stock and if you put a pipe on you'll probably gain it all back and then some, as long as you jet it correctly. also get a UNI air filter, it flows higher and with the combination of the new exhaust will help the engine breathe better, again, as long as you jet it right.
I've heard horror stories about k&n filters, try to stick to the oiled foam type to protect your investment.
Old Feb 6, 2006 | 03:28 PM
JeteNuts's Avatar
ok thanks, ive already looked at the Uni filter with the supertrapp IDS2, however what sizes jets would you run? i know my friend installed mine, since he races a honda 450, but i think he used two sizes up on the main and one on the other! not 100% sure! however i believe it was the one for altitude of 3k feet or simialiar, can you comment on the jetting aspect and what altitudes represents each one, because if i see the altitude i can tell you which one! thanks
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
