KAZUMA ADULT ATV 250 4 STROKE AUTO
Old Feb 6, 2006 | 01:50 AM
SEADAWG's Avatar
Default KAZUMA ADULT ATV 250 4 STROKE AUTO
DOES ANYONE HAVE EXP. W/ THIS QUAD. I JUST PURCHASED ONE. GREAT OUT OF THE CRATE. HOWEVER, IT STARTS ...WELL LETS JUST SAY THAT IT IS THE COLDEST BLOODED THING I HAVE SEEN AND THE LOW TORQUE IS SO SLOW I FEEL LIKE I'M RIDING A BRIGES AND STRATTON GO-CART. I'M REALLY AFRAID OF TAKING THIS ON THE TRAILS...EVEN JUNIOR TRAILS. IT IS OKAY ONCE IT GETS THE RPM'S UP, BUT IT TAKES TIME OR NOT AT ALL AND BOGS DOWN. I JUST WANT TO KNOW IF IT NEEDS TO BE BROKEN IN OR IS IT REALLY THIS WEAK??? MY DEALER WAS GREAT, NO MIS-ADVERTISING....GREAT PRICE, GREAT SUSPENSION, GREAT HEIGHTH AND SMOOTH CHASSY...JUST ??? I'M SORRY, THE ENGINE NEEDS STERIODS BIG TIME. PLEASE HELP OLE SEADAWG UNDERSTAND.
Old Feb 6, 2006 | 12:42 PM
Quicknick's Avatar
Hi Seadawg, my 250 ran the same as you described. Be sure to drain the carb bowl and oil the air filter foam. The valve adjustment helped alot also. Then if it is still to bad to ride. You will have to rejet the carb. I raise the needle on notch and resized the pilot jet with a #78 drill bit. That only removed about .002". Try the other stuff first. When you get it right they run good.
Good Luck
Nick
Old Feb 6, 2006 | 02:48 PM
happydad's Avatar
Good Luck
Nick
quicknick, you raised the needle one notch, please fill me in on the procedure. i assume that its self explanitory once you get the carb taken apart? thanks joe.
Old Feb 6, 2006 | 03:38 PM
Quicknick's Avatar
Hi happydad, 1st remove the carb. Then remove the top cover. It is spring loaded. Next remove the diaphram and slide assembly. Using a 8mm socket turn (by hand) the plastic nut 1/4 turn and it will come out. Gently push the needle up from the bottom. Once this is all out of the slide you can simply move the clip one notch down. This will raise the needle. Reassemble and replace the carb.
Three things to be careful about.
The clip on the needle can fly across the room and be lost forever. Do this in a clean area and be careful.
The second thing is to be sure the needle goes into the needle jet (hole in carb) when replacing the slide.
Third, the diaphram has a index notch so the slide faces the airflow properly. You will be able to see the index in the grove on the carb body that the diaphram seats in. After it is all together push the slide up into the carb and it should go all the way up and come back down slowly
Old Feb 6, 2006 | 05:27 PM
happydad's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img] thanks for the info qicknick. gonna do it tonight.
Old Feb 6, 2006 | 06:58 PM
SEADAWG's Avatar
Guys,
Thanks for the advice...I'll try it and post it tomorrow. Hope this works...thanks for helping me out. SEADAWG
Old Feb 7, 2006 | 12:53 AM
SEADAWG's Avatar
All, I adjusted the valves, drained the carb, oil the air filter and put a lock tie around the intact rubber. It has better response and is doable. Seadawg
Old Feb 12, 2006 | 09:19 PM
SEADAWG's Avatar
All, thanks for the help. I've tried everything and this is just a design/engineering flaw. I hope the aftermarket fixes this low RPM problem. Although I was not mislead, I'm just shock this is so weak at the low end. I'm still scared to take it to the woods. If you hear of any aftermarket carbs or things that will allow this to have the UMPF in the engine that it has in appearance!! SEADAWG
Old Mar 5, 2006 | 11:05 AM
i8amm's Avatar
There's a post under Raceway ATV's on what I did to my falcon 250 to get it running better. It's a real powerful unit right now. It is running way better than I expected it would.
i8amm
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Clint Russell
Sep 25, 2015 03:20 PM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
