ds rear shock, please help
Old Feb 6, 2006 | 09:19 PM
savagebeating's Avatar
Default ds rear shock, please help
Hi I have a question about the ds rear shock
I need to know if it needs to be rebuilt or re filled or just set up wrong
when I first got it i set the spring stiffer and then it was bouncy so I set the bottom adjust ment more clockwise
which helped from it spring back up but the rezy I turned clock wise to get the compression high so it goes down slower but when i shove down on the back handle it goes down really fast but comes up slowly
which way do you turn the rezivior adjustment clock wise or counter clock wise?
I checked and the shock does not leak so what would cause this, do I just need a shot of nitrogen.
Thanks
Old Feb 7, 2006 | 01:48 AM
FatHolly's Avatar
OK first righty tighty lefty loosey.
Next the adjustment on the rezzy is the compression adjustment. That controls the you on the way down. The adjustment at the bottom is the rebound. Controls on the way up. If you are bottoming out you need to tighten your compression... tighten the adjustment on the rezzy. If your too hard on landings you need less compression. Loosen rezzy adjuster. If your rear is packing up you need a little less rebound... loosen your bottom adjustment. If your are bouncing side to side off whoops, you need more rebound... loosen bottom.
You also need to set your ride height... I think I have about 5 inches of sag. Pull the bike all the way up and measure at the grab bar. Sit on it jump around a little and measure. 5 inches of sag from the top. Set that with the collar on the spring. Then adjust the shock to comfort.
If it is still not dampening at all, then you should have a look into rebuilding it.
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
Sep 9, 2015 10:56 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Tim Shoe
Sep 7, 2015 12:15 PM
black_thunder
Sep 7, 2015 01:24 AM
