Help With A 1982 200E Charging System
Old Feb 7, 2006 | 04:18 AM
RedRider69's Avatar
Default Help With A 1982 200E Charging System
Hey Thanks For Spending some time on my problem! I have a charging issue and its weird.
As you know its battery powered and had a regulator rectifier. when its running and the headlights on and the batterys taken out and i turn on the headlight it turns on...but kind of dim. And then when I go to check the terminals for the battery with a volt meter theres nothing. so does it mean that its not charging but the headlight system works or what? what would effect that.
I just bought the unit not that long ago and am thrying to restore it. So i took the motor out today because it was burning A LOT of oil and leavs oil residue in the tail pipe and is given that its either rings or valve seals. so as I'm fixing that is there anything I should check for the charging system while I have the motor out?
Old Feb 7, 2006 | 05:53 AM
ThrashAndCrash's Avatar
You should buy a book for it and test the stator to spec. Pay close attention where the wires go into the stator cover. When you Ohm out the wires, wiggle them where they go through the cover. I have had quite a few go bad in that spot.
Old Feb 7, 2006 | 06:29 AM
RedRider69's Avatar
The Stator's Located where?
Thanks!
Old Feb 7, 2006 | 12:13 PM
HondaAtcRoxz's Avatar
The stator is connected to the wires that are comming out of the motor. Thrash is right the wires might have worn out where they come out of the motor grounding themselves out.
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
