Secondairy spring
Old Feb 7, 2006 | 10:47 PM
Gurney's Avatar
Default Secondairy spring
what dose the secondairy spring acctully do? i get what the primary dose but what can i exspect 2 gain puttin on a secondairy spring?
Old Feb 7, 2006 | 11:44 PM
handycap's Avatar
Secondary spring does the up shift. The stiffer the spring the longer it stays in low, and also faster back shifting when slowing down.
A stiffer spring will keep the revs up higher longer before the shives change position and change the effective gear ratio for the up shift, causing a harder acceleration.
You can look up Aaen Polaris web page and read about it.
Old Feb 8, 2006 | 12:02 AM
ftwflh's Avatar
THe secondary clutch senses the load on the wheels and upshifts and backshifts according.Stiffer spring and higher the setting the faster it backshifts.Also controls grip onthe belt along with various other things.But basicly it controls backshift.
Old Feb 8, 2006 | 02:59 PM
Gurney's Avatar
so all in all harder accel and faster decel
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
