Front steering pulling hard right
Old Feb 8, 2006 | 09:18 PM
textrout's Avatar
Default Front steering pulling hard right
I need a little help please. I had a boot break and before I got it fixed, my grandkids nad wife rode my Polaris Trailboss (350L 1993) a little. Anyway, I went out there and they said it had been steering funny. Well, yea! the wheels were going in opposite directions when I saw it, with the FRONT RIGHT outside steering knuckle broken and the A-arm broken, and then of course the shaft pulled ot of the cv joint .
I have fixed everything back up now, with taking everything apart on that side, new boot, cleaned and greased CV joint new A-arm & bushings, Checked and cleaned all the bearing, filled the wheel cylinder with oil, etc. The very first thing I noticed was it wanted to pull hard right. I only rode it a few feet to notice this. T(his was the problem I think it started having when all the things broke.) This is when it is not in 4WD (I checked!) Can you give me a heads up on what I didn't do correctly or what else might be wrong? The alignment looked normal/OK when it was still up on the rack. One thing I don't know about is if there is any "timing" of the shaft in the outside CV joint. I know there somebody on here who knows what's up and can help me. Thanks in advance guys.
Old Feb 8, 2006 | 09:35 PM
2manytoys's Avatar
You may want to put it in the air and see if the 4wd is stuck on or if something is binding. The front has a clutch assembly in each hub. Either the clutch is bad or the armature plate is warped. . If you had to fix the cv you may have put the front hub together wrong also.
Old Feb 9, 2006 | 02:02 PM
textrout's Avatar
Not a bad idea, to put it on the rack and see. But I think something was wrong before to have caused such severe problems (possibly unrelated to the boot or CV joint).
Question: Could a bad CV joint cause it to pull hard right like this when the 4WD is not ingaged?
Textrout
Old Feb 9, 2006 | 05:33 PM
doctorvic's Avatar
It sound like the axle is not in the cv joint I had this same problem with my sportsman when I installed a front lift.
I would put it back on the rack and pull the cv boot to make sure everything is together.
MikeyBoyesq
Nov 27, 2020 02:44 PM
WilliamBos
Sep 30, 2015 08:08 AM
toonces
Jun 30, 2015 11:19 AM
traumajunkie
Jun 30, 2015 04:28 AM
VRRRRT
Jun 27, 2015 09:38 AM
