difference in stock explorer 400 pipes?
Old Feb 9, 2006 | 05:45 PM
94sport400L's Avatar
Default difference in stock explorer 400 pipes?
Does anyone know what the difference between the 95 and 99 explorer 400 stock pipes/exhaust is?
World of power sports lists different part #'s but the pics look the same.
Thanks
Old Feb 9, 2006 | 06:19 PM
conig's Avatar
if the explorer is like a sport most likly its the frame around the start of the reat fender. the older ones come out more which prevents the newer exhaust/ after market pipes from fitting on as a bolt on instalation.
Old Feb 9, 2006 | 08:30 PM
ftwflh's Avatar
They should be interchangable.Go to a dealer and see if Polaris has changed part numbers on them and if so what the dif is.You may be able to make it work. Sorry I checked Aaens catolog and they are dif .
Old Feb 9, 2006 | 10:03 PM
WIscrambler's Avatar
The 99 Explorer is probably concentric drive. I don't know if Explorers are the same as Scramblers, but concentric drive scramblers use a different pipe than non concentric drive scramblers.
Old Feb 10, 2006 | 02:18 PM
Thanks for the ifo guys. I will try and contct the polaris dealer out here to see if there are major differences.
Hopefully it may just be the way its mounted to the rear of the frame.
Why would you need a different pipe if it was concentric or nonconcentric?
Old Feb 10, 2006 | 05:25 PM
conig's Avatar
Originally posted by: 94sport400L
Thanks for the ifo guys. I will try and contct the polaris dealer out here to see if there are major differences.Hopefully it may just be the way its mounted to the rear of the frame. Why would you need a different pipe if it was concentric or nonconcentric?
the frames are a tad different starting at the front sprocket and goung up. I beleive its becuase of the brake being on the drive sprocket as opposed to the axle.
Huntingdeer
Aug 23, 2015 12:06 AM
Proud Father
Aug 19, 2015 10:08 PM
Stever6368
Aug 16, 2015 07:34 PM
traumajunkie
Jul 23, 2015 02:10 AM
cSchwartz
Jul 12, 2015 07:42 PM
