2001 banshee ?
Old Feb 9, 2006 | 09:17 PM
omar's Avatar
Default 2001 banshee ?
does anyone know where to adjust the idle speed on this banshee 2001.
Old Feb 9, 2006 | 09:20 PM
nosaddic's Avatar
if its stock you can adjust it at the tors located on top of the carb lift the seat and you should see a large flathead screw clockwise to go higher counter to go lower. if the tors are gone you should have a brass screw on each of the carbs facing out
Old Feb 9, 2006 | 09:30 PM
enFORCER's Avatar
Ajust the idle by turning the pilot air screw on the carburetors. It's that little screw at the end of the carb, close to where the air box boot connects to the carb.
Old Feb 9, 2006 | 09:42 PM
enFORCER's Avatar
I might add do what nosaddic said first. If the TORS is removed then go to the carbs.....
Old Feb 9, 2006 | 10:54 PM
omar's Avatar
so if i just take off the seat you could see the tors?
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
chewy78
Sep 8, 2015 10:37 AM
