scrambler rear shock bolt problems
Old Feb 11, 2006 | 06:57 PM
Hoopie's Avatar
Default scrambler rear shock bolt problems
Old Feb 11, 2006 | 06:59 PM
Hoopie's Avatar
I am trying to take off my rear shock to take in to get rebuilt but I cant bet the top bolt out. any suggestions? The bottom one came off fine. The nut came off without any problems either but the bolt wont come out of the frame whole.. I just spins freely.
Old Feb 12, 2006 | 01:14 AM
scramblerXrated's Avatar
its prolly worn or bent or both, this might call for drastic measures.
i have had this happen also. the right size c-clamp will help you press it out. u gotta kinda offset the one end to allow the bolt to slide out.
hope this helps... good luck.
X
Old Feb 12, 2006 | 01:47 AM
Hoopie's Avatar
Thanks Scramblerx for the reply. I not sure I understand though. I have C clamps but what do you mean offset to get it out?
Old Feb 12, 2006 | 02:52 AM
well one end needs to be on the end of the bolt, and the other end obviously cant be on the other end of the bolt, but it needs to be off to the side of the bolt(offset), and it will let bolt come out. its kinda funky, but its werked for me.
hope this helps...
X
Old Feb 12, 2006 | 11:34 AM
Hoopie's Avatar
I get it now. Thanks! I will give it a try.
Old Feb 12, 2006 | 04:16 PM
Hoopie's Avatar
I tried a clamp to try and press it out and no luck. any other ideas?
Old Feb 12, 2006 | 07:20 PM
heatseeker8's Avatar
For Christ's sakes Dont FORCE it!
get a BIGGER hammer
Old Feb 12, 2006 | 08:16 PM
Hoopie's Avatar
i tried using a punch with a 22oz hammer! still no luck. I sprayed wd40 on it also. I think maybe the bolt is attached to the bushings. I dont know what else to try besides borrowing my neighbors impact wrench and driving it out. THis is ridiculous! I dont want to damage the shock obviously but it seems the only way i may get it off is to cut the bushings out. URRRRRRRRR
Old Feb 15, 2006 | 05:52 PM
Update?
