pilot cylinder on 250R
Old Nov 9, 2000 | 09:58 PM
ridzhard's Avatar
Who knows anything about the Pilot cylinder on a 250R motor? Any info on this would be appreciated because I came across a R motor with no cylinder on it. How does this motor run compared to a ct big bore(pro-x) and how reliable is it? Thanks in advance.
Old Nov 10, 2000 | 01:30 AM
Mohs87Warrior's Avatar
Dirt wheels did it in a mag. last year some time. I not sure of the month though...
Old Nov 10, 2000 | 08:49 AM
Backcountry's Avatar
Let me root around and see if I have Dennis Packards ph. # Packard Enterprises builds the fastest Pilot hybrid motor out there. They WILL spank the Pro-X motors, but they tend not to be as reliable. It's more of a dune hillrace type set-up. Although he can build you just about anything that you would want.
Old Nov 10, 2000 | 12:03 PM
Static-X's Avatar
www.ftzracing.com this will point you in the right direction. PSI does the same thing except with what I think is a polaris cylinder. joe byrd runs the PSI in open quad pro. it should be reliable.
Old Nov 10, 2000 | 02:24 PM
PSI has been chiefly focused on sleds in the recent years, but now has taken an interest in quads and dirt bikes.
The cylinders that they offer for the 250R were designed with the 250R in mind. I spoke with thier reps at the Snowmobile Expo we recently had here and they were very helpful in answering the questions that I had. The port design is different from that of the Pro-X and stock cylinders. It's a triple exhaust, and in the biggest bores, they have additional aux transfers that dump down in the bottom end via the intake floor.
The cylinder also employs a variable exhaust pressure valve (VEP), the is just a different variant of a "powervalve".
I suspect that these cylinders while pricier than the Pro-X will begin to show up and start posting some impressive runs.
I would look into these as well before trying a pilot hybrid motor.
www.psiperformance.com
Old Nov 11, 2000 | 11:00 AM
ridzhard's Avatar
Thanks for the help with this. Whichever way I go it looks like a long term project as cubic dollars are required and it is not something I need to have in order to go riding right know.
Dewhound
Apr 20, 2017 02:25 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
