honda450foreman backfireing
Old Feb 14, 2006 | 05:06 PM
canat's Avatar
Default honda450foreman backfireing
I have a 2000 honda 450foreman and when your going 60% or upwards of throttel for any lenght of time then knock of the gas she back fires esp if you do it going down hill.I HAD A 300FORTRAX and it use do the same when low in gas but this doesit even with a half tank the plug was changed about 200hrs ago would that be the problem? any answers would be greatly app.
Old Feb 15, 2006 | 12:48 AM
1988TRX250R's Avatar
Could possibly be running lean. Does your muffler rattle like the baffle is loose inside? Had one today where that was the case. I hit a bump w/ it and the baffle must of shifted just right and it had absolutely no power, let off the throttle and it would go again ok. I have replaced mufflers in the past w/ loose baffles and the machine would stop backfiring after replacing. Your muffler may be fine, but this is something I have seen before.
Old Feb 15, 2006 | 03:12 PM
hondabuster's Avatar
Sounds like lean idle circuit to me, too. Colder temperatures lean out the jetting, and yours might just be on the edge of lean.
Check for exhaust leaks and intake leaks, either one can cause the popping.
If the intake and exhaust look good, then adjusting the mixture screw richer (out), maybe 1/8 to 1/4 turn should fix it.
Do you use pure gas, or ethenol blended stuff? If you use the blended stuff, try a full tank of pure gas, and see if it gets better. The ethenol blended stuff is about 10% leaner than pure gas.
Welcome to the forums.
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
