NEW spark plugs E3
Old Feb 15, 2006 | 05:26 PM
damronwalton's Avatar
Default NEW spark plugs E3
I some cool new spark plugs for both 2-stroke , 4-stroke , small engine and big engine.
E3 is an entirely new kind of spark plug producing 8%-12% more power while increasing fuel efficiency up to 13% and other one ENGRGY increases both 2 and 4-cycle power up to 8%-12% over other brands better combution reduces carbon build-up and extends engine life.
EFFICIENCYuse less gas-as much as 13% less versus other spark plugs. Work longer with fewer fill-ups.ECOLGY reduces toix emission up to 58% in long-term use, versus the leading spark plug. Do you think some cool? I have one spark plug number is BR7ES for my on xplorer 400 4x4.
xplorer 400 4x4 2001
with 26 inch tires and
force reed 2 bit more
bottom end power
Old Feb 15, 2006 | 05:36 PM
DSLKSL's Avatar
I put one in a 10 hp gocart. Ran for about 3 days and the threaded top viberated off and was lost.
I called E3 and sent e-mails....they never did respond.
I would make sure the top electrode can't come off, if you get one.
Old Feb 15, 2006 | 05:41 PM
watzupdog's Avatar
stick with NGK. thats what polaris wants you to use. if you want you can upgrade to the NGK IRIDIUM.
Old Feb 15, 2006 | 05:46 PM
Hey DSLKSL I have never a problem on spark plug for 3 mouth ago my engine much power on xplorer 400 4x4 nothing with wrong spark plug. Do you have your problem a spark plug 10 hp gocart?
bottom end poweer
Old Feb 15, 2006 | 05:48 PM
NGK IRIDiUM are cool
Old Feb 15, 2006 | 06:33 PM
DSLKSL's Avatar
No the plug is ok, I replaced the top and crimped the top edge so it would not come off.
Not sure why some plugs are made like that?
Old Feb 15, 2006 | 11:24 PM
mistertinker's Avatar
the reason the cap threads on and off is because of the different spark plug connecters. some push onto the threaded part and others push over the cap thats threaded on. when you buy a plug that has a threaded cap always take some pliers and make sure it is tight before using it.
Old Feb 16, 2006 | 12:46 AM
IdahoVinnie's Avatar
On my snowmobile, I had a problem with a black debris build up on the threaded caps (possibly causing added resistence) that were silver in color. I replaced those caps with brass caps from some automotive plugs. Problem solved.
Old Mar 2, 2006 | 01:56 PM
Spark plugs E3. Do you have a trouble with your spark plugs E3? You will let me know ok. I will try one a new spark plug NGK IRIDIUM what number is? For my xplorer 400 2-stroke.
hot seat pipe, hot seat clutch kits,
Hi comp 12:1 head, force reed 2,
26 inch tire good year mud runner,
front fox shock, rear fox shock
Old Mar 2, 2006 | 06:47 PM
watzupdog's Avatar
When I checked the NGK site. It gave me BR8EIX.........But it also said that it replaced the Original plug that was BR8ES. In your post you said that yours was a BR7ES. Someone on here with the same machine might verify for you that the OEM was a 7 and not an 8. Anyway there great plugs....runs you about $6.95. I got mine from Oriellys auto.
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
