250R ATC motor compatibility
Old Feb 16, 2006 | 12:02 AM
cullen3's Avatar
Default 250R ATC motor compatibility
will a 1984 250r atc motor fit a 1982 frame? Are the 1981 through 1984 motors all the same?
Old Feb 16, 2006 | 10:52 AM
JkAss's Avatar
Welcome to the forums!!! I don't believe they are exactly the same, but are very close. If it doesn't fit, it shouldn't take muck to make it fit. Good luck, the 84 is a strong reliable engine.
Old Feb 16, 2006 | 03:24 PM
1bad450r's Avatar
The engine itself should be the same and fit no problem.
Old Feb 17, 2006 | 09:10 PM
Blazerone22's Avatar
You must change out the shifter shaft, 81-82 are the same 83-84 the same.
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
