1991 250 trailboss 4x4
Old Feb 19, 2006 | 10:16 AM
indiangirl's Avatar
Default 1991 250 trailboss 4x4
husband got 1991 250 trail boss 4x4 and not even 24 hours later our son rolled it. The right side handle bar was bent pretty good. We bent this back and thought ok not bad could have been worse. But now we noticed that when you goto put it in reverse it revs up pretty high. Someone suggested checking to make sure all the connectors were still connected. Did that and everything seems to be ok.We can not seem to figure this out. Can any one help with this please. Thanks
Old Feb 19, 2006 | 11:35 AM
drlang's Avatar
Sounds like the throttle cable got messed up. The reverse thing doesn't make much sense. does it rev up with the handle bars turned either way?
Old Feb 19, 2006 | 01:39 PM
2000scrammy's Avatar
Welcome to the forums. I can't help you too much on this topic but does it rev up once its in reverse or when your trying to put it in, like neutral on the way to reverse.
Old Feb 19, 2006 | 08:29 PM
indiangirl's Avatar
in low range,neutral,and high range, The idle is fine. As soon as you start to engage it in reverse or have it in reverse the idle goes to the rev limiter point.Does this make sence cause it does not to us. [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Feb 19, 2006 | 09:02 PM
Fenton88's Avatar
hmm...would reverse override come into play here?
just a thought
Old Feb 19, 2006 | 09:34 PM
IDK what to tell you but it sounds like a wiring problem somewhere, thats my best guess anyways. Or maybe when you put it into reverse it hits and pulls on the throttle cable somewhere somehow. Was it fine before the rollover or was it not put into reverse.
Pehter
Oct 3, 2024 11:00 PM
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Myronh
Sep 8, 2015 11:27 AM
