banshee only smoking on one side! help???
Old Feb 23, 2006 | 07:56 PM
240r's Avatar
Default banshee only smoking on one side! help???
Hi I got this banshee about 3 weeks ago and when i start it i only smokes on one side. its running stock carbs with 330 jets. the motor is race ported, fmf pipes kand N filters higher compression. When sitting on the bike its the right side cylinder, and the pipe on this side doesnt warm up like the left side. Its getting spark and fuel, i tried ajusting the idle on the carb and didn't change any thing. PLEASE HELP!!!
Old Feb 23, 2006 | 08:00 PM
enFORCER's Avatar
Sounds like you mighy have a bad crank seal.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Feb 23, 2006 | 08:55 PM
wideopenrider's Avatar
Check simpliest things first. Might want to check your rings on that side
Old Feb 23, 2006 | 08:57 PM
240r's Avatar
my compression is at 115psi on both sides and i live at 5000 feet!
Old Feb 23, 2006 | 09:07 PM
well 115 isn't much for a high compression banshee. But the other guy might be right with your crankseal. he looks like hes tore into his banshee pretty exstensivly. might wanna take some carb spray and spray around your seals when its idiling and see if anything changes. You know the drill i'm sure.
Old Feb 23, 2006 | 09:08 PM
if you can't figure you it. Do the smart thing, get rid of the banshee and get a 4 stroker
Old Feb 23, 2006 | 09:12 PM
240r's Avatar
where is the crank shaft seal??
Old Feb 23, 2006 | 09:29 PM
240r's Avatar
how hard is it to check the crank seal and how hard is it to replace??yhis thing runs like a champ at mid to top end but at idle it runs like crap and dies!
Old Feb 23, 2006 | 10:08 PM
The crank seal is between the crank and the case.
And you could check your plunger needle on your carb, maybe you could adjust them up or down to richen or lean out on top or bottom. if you don't know the carbs good, it may be wise to take it to a shop. Sometimes its gets a little frustrating. I had a 250r with some issuses. [img]i/expressions/face-icon-small-frown.gif[/img]
Old Feb 27, 2006 | 05:51 PM
Sin's Avatar
Sin
LOL going from a bike like he has to a 4 stroke would be like going from a ferrari to a Ford festiva....the nice things about 2 strokes you'll find for the most part they are VERY easy to work on and parts arent too overpriced. Try rebuilding a 4 stroker...what a nightmare. I would check the seals hell...you could pull the motor and split the case...might as well weld the crank while you're in there If its not welded youll wish it wouldve been when that crank starts to walk,now that would be an expensive repair. Its a good idea to have it welded with the mods you listed.
