83-85 200x and 200m engines
Besides the manual and auto clutch on the 200's and kick and pull starter, whats the difference between the two engines?
Is the gear ratios the same?
Is the bore the same?
Any thing else the same?
Thanks.
Thanks.
Nothing in the bottom end is the same other than a few fasteners. The gear ratios are also different.
The only differences in the top end is the cylinder on the X has larger cooling fins, the camshaft has a different profile, a higher compression piston in the X, and the rocker cover on the X doesn't have the cable operated decompression lever.
Same porting and same valves.
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
