How to install 1/2 in. reed spacer? PLEASE HELP
Old Feb 28, 2006 | 10:02 PM
fastestkidaround's Avatar
Default How to install 1/2 in. reed spacer? PLEASE HELP
How do I install my reed spacer? And were at?
Old Feb 28, 2006 | 11:12 PM
warriorryder's Avatar
you install it in between the reed cage and the intake manifold/boot
Old Mar 1, 2006 | 12:33 AM
Well I found that part out. Thanks though. I cant seem to get it on so I am trying ot take off the varb and I cant get the oil plug thing off, and I cant get the air boot things on both sides of the carb (the black rubber thing). I am having a bad first exp. with my carb. I am not going to put that tors thing on again, if I stay with that carb. I am planning on putting the z400 shock on thier and putting a 28mm carb, a 14 tooth front sprocket, parking brake block off, and maybe my oil block off kit, on their before I put the thing, back together. I am freezing my a$$ in the garage since I cant get the fire going, and its 10 below. And I am going to leave the thing alone intell I can get more parts to put on their.
Old Mar 1, 2006 | 11:55 PM
okay I got the thing on and I am on ebay bidding on a cr 85 28mm carb. I cant get the bottom left screw in thought because the carb is in the way.
Old Mar 2, 2006 | 02:36 AM
KDracer's Avatar
Try removing the air box then the carb and then installing your reed spacer, get rid of the oil injection system and just permix the fuel. there is no reason not to use the stock carb, if you are running the stock air box lid take off the snorkel and dirll a bunch of holes inthe top of the lid apx 6-8 1.5" holes. and install a K&N.
that should put some more pop in your ride.
Old Mar 2, 2006 | 02:51 AM
Okay I will try that. By the was my sig. says my mods and I have a k&n w/ outerwears, and I have 5 holes on top of the air box lid, and 1 in the air box lid where the air comes through, and already removed the snorkel. But I am going to try removing the air box and carb, or can I just remove the carb?
Old Mar 2, 2006 | 05:39 PM
KDracer's Avatar
try to removed the boot form the box to the carb by folding it back on it self this will aid you in the reinstall for the boot. then you can removed the carb an install you spacer.
Old Mar 3, 2006 | 12:38 AM
Okay I am going to do that this weekend when I install my z400 shock if I can figure that out to.
ReconBayou
Oct 31, 2022 05:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
2many2ride
Sep 27, 2015 04:35 AM
toonces
Sep 5, 2015 01:14 PM
