brake problems
Old Mar 1, 2006 | 08:05 PM
frndinalowplace's Avatar
Default brake problems
my uncle just replaced a brake line on his 04 500, from the caliper to the distribution block, he said he bled everything correctly, and tried it a few times yet he still gets a spongy feeling in the handle, like a buble in the lines anyone have an clue y this is still happening?
Old Mar 1, 2006 | 10:04 PM
mudslinginfool's Avatar
Does it in the Mud!
its deffinately a problem arctic cat needs to adress. ive had mine(an 02 500) in the shop 6 times under warrenty for that reason and never is fixed correctly. works for about 5 minutes if im lucky. finaly i decided to change my brake pads which only took about half hour to do and they work fine now. i dont understand why these new machines are doing this.
Old Mar 2, 2006 | 10:47 AM
Bear4570's Avatar
If the brakes were working ok before the line was changed, then they still aren't bled properly yet. You will probably have to bleed all 3 of the calipers as there appears to be air still in the system.
Old Mar 2, 2006 | 11:47 AM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Arctic Cat's have brakes!!!!! [img]i/expressions/face-icon-small-happy.gif[/img]
Just Kidding, they have come a long way.
Old Mar 2, 2006 | 12:02 PM
wideopenrider's Avatar
Oh who needs brakes? lol.
jk
AC's still have great stopping power even with the spongy feel, well...atleast mine did.
Old Mar 2, 2006 | 02:52 PM
umm i had already stated that EVERYTHING had been bled, that includes the other three calipers and in correct order, it had been bled completely through at least 3 times to the point where it could even been gravity bled.
Old Mar 3, 2006 | 01:54 PM
Bear4570's Avatar
I have never had gravity bleeding remove a bubble. As far as I know pressure bleeding is the only way to remove a bubble. Are you using DOT 4 brake fluid?
toonces
Oct 16, 2019 12:11 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Chuck188
Jul 17, 2015 02:45 PM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
