Blaster Clutch Problem
Old Dec 14, 1999 | 11:10 PM
MrInSaNo's Avatar
Hey ... i was riding my blaster the other day when my clutch lever all the sudden got stiff to where i couldnt pull it in ... i pulled it a couple of times and then i finally was ably to pull it in .. i thought ok no big deal .. so then i started my quad back up again and tried to take off but when i let my clutch out nothing happened. i tried this in all 6 gears ..i looked at the left side of my quad where the clutch cable connects and when i pulled the clutch in the piece moved like it should.
My friend that raecs motocross bikes said it sounds like it might be my clutch basket. What might the problem be?
Old Dec 15, 1999 | 01:20 AM
thumper4x4's Avatar
If the lever moves and nothing happens, looks like the covers got to come off for inspection.
Hope this helps...
Old Dec 15, 1999 | 05:43 PM
sAyIt_fmf's Avatar
When this same thing happen to me...It was caused by the screw in the center of the clutch (remove the side cover)... You will probably find that it backed itself out.
If you continued to pull the lever...you might have broke the cable inside the sleeving... But my guess is that the screw backed out and when you pulled the lever...you popped the screw into the bottom of the engine....releasing the pressure on the plates....the lever will move, but nothing will happen...Hope this helps...and I would be interested to know how close I came...thanks.
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
