metal shavings?
Old Mar 4, 2006 | 05:05 PM
v2rider's Avatar
Default metal shavings?
I changed my front and rear differential oil today, just to switch it to synthetic, and i noticed a small amount of very fine metal shavings on the magnetic tip of the drain plug in the front and rear. I have 500 miles on it, and was wondering if finding a small amount is normal or not. It is a 06 650V2.
Old Mar 4, 2006 | 05:46 PM
Bear4570's Avatar
This is pretty much normal on your first lube change. If it has this much next time around, then it's something to work about.
Old Mar 4, 2006 | 07:59 PM
v2rider's Avatar
Thanx bear, thats reassuring.
Old Mar 4, 2006 | 08:30 PM
petroleumboy's Avatar
V2Rider,
What type of fluid are you running in your diff's? Makes me think I should do mine as I have almost 900 miles on mine.
Old Mar 4, 2006 | 10:10 PM
v2rider's Avatar
I am using Ams Oil 75-90 weight. I ran this in my 93, and it still has yet to have any probs with the differentials. 13yrs old isnt bad!
Old Mar 4, 2006 | 10:41 PM
I was hoping you'd say that. I have 8 litres of the stuff sitting on my shelf in my garage. I'll have to change it out. Quick and easy to get at?
Old Mar 5, 2006 | 01:26 AM
v2rider's Avatar
Yes, the fill plug is an 11/16, and the drain plug is a small screw into the side of the bottom of the case. If you have an owners manual it illustrates it. You will need a long flexible funnel, and the manual doesnt specify how much oil to put back in, so just fill it about 1/2 inch below the fill hole. You can visually guess this amount by looking into the hole. Its about 10 ounces
Old Mar 5, 2006 | 03:51 AM
weez440's Avatar
the best way to judge how full it is, is by taking a piece of wire and benging it so you can stick it in the hole to check the fluid level. and well i supposed i should check mine lol 1700 hard miles and never checked or changed but i am looking at trading it off anyone interested in buying it???
Whitelx1
Oct 2, 2015 10:55 PM
bigred20653
Oct 2, 2015 10:05 AM
firsttimerider
Sep 20, 2015 09:07 PM
nastyblaster100
Sep 13, 2015 01:19 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
