Big proublem.... Need Advice
Old Mar 12, 2006 | 09:31 PM
Britta's Avatar
Default Big proublem.... Need Advice
OK, saturday i was riding on an onld strip mine and go the idea to cross a sediment pond and it was a little deeper than expected and suck water down my snorkel and now i have changed the oil three times and is still coming out milky white. What should i do.. i have cleaned the air filter very good and everything the model is TRX450 Foreman FM S all stock.. ..
Old Mar 13, 2006 | 03:18 PM
v2rider's Avatar
Buy the cheapest oil you can, and lots of it. Buy Three oil filters. Change the oil, run it for 10 minutes. Repeat this until you have no signs of water in your oil, but keep the same oil filter on it. Now change the oil with the same cheap oil, and a new filter, and run it for 10 min again. Now change it again with the oil you want in your wheeler, and the third new filter, and you should be good to go. Expensive and time consuming mistake, but not as exspensive as it would be if you didnt clean it properly and rode it anyway!
Old Mar 13, 2006 | 04:01 PM
BigRed1985's Avatar
hey britta, does it smoke really bad now?
Old Mar 13, 2006 | 04:43 PM
bigsam's Avatar
Add 1 qt. of Marvel Mystery Oil in place of one of the quarts of cheap oil when you change. It will help get the moisture out of your oiling system.
Old Mar 13, 2006 | 10:11 PM
Britta's Avatar
NO thank god there is no smoke cause that would mean rings right:? pistons etc?
Old Mar 14, 2006 | 06:20 PM
BigRed1985's Avatar
lucky you.... [img]i/expressions/face-icon-small-mad.gif[/img] , lol i did the same to my beartracker, and now i need a complete rebuild, it statred smoking bad., well good luck , i hope you get it str8ened out.
Old Mar 14, 2006 | 07:04 PM
Britta's Avatar
Omg people... today i started it up and it started to smoke. It was very cold and i had to choke it? am i ok? god i am scared. what costs am i looking at if i have to rebuild?
Old Mar 14, 2006 | 11:18 PM
v2rider's Avatar
They all blow some color out at first when not warmed up, if it doesnt quit after a while, then Panic
Old Mar 15, 2006 | 08:11 AM
BigRed1985's Avatar
Wiseco is $90 for a rebuild on www.bikebandit.com, but I seen i cheaper brand one on ebay for $60, I hope you get it straightened out without a needing a rebuild.
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
